Buck-Boost Converter for High Voltage
yoshua habibnur q
Joined Apr 16, 2017
8
i got a project with spec :
  1. Vin = 300-340 Vdc
  2. Vout= aprox. 312 Vdc
  3. with load at least 500 Watt
so i use parts my buck-boost with this value
Fsw = 15kHZ - 25 kHZ (using optoisolator TLP250 so cannot above 25kHZ)
L= 3mH
C= 1mF
diode = MUR1560
Mosfet = IRFP460
But, the inductor current goes too high even with input 40 Vdc (duty 50%), the inductor current can reach 6 A with no load(voltage signal is good though like a pure DC). Any solution for this problem? or is there any other suitable topologies for spec above?
DickCappels
Joined Aug 21, 2008
10,661
Increase primary inductance and/or increase the frequency.
We would like to see your circuit. Can you get rid of the opto coupled driver and use a faster one?
yoshua habibnur q
Joined Apr 16, 2017
8
this is my circuit below with with control circuit PWM (arduino UNO and TLP250), if i use higher frequency, what driver and/or optoisolator should i use? lets say above 100khz
moderators note : shown image full size
ian field
Joined Oct 27, 2012
6,536
Your circuit is actually an inverter. TI published a book on SMPSU topologies - I think you can download the PDF. Try archive.org first, but it must be around somewhere.
Bush Rank Murphy used this topology in one of their early solid state TVs, but it didn't eliminate the live chassis.
Buck/boost is harder to do (costs more) so most commercial manufacturers use the flyback topology driving a transformer. You can arrange for the output voltage to be within the adjustment range you need, and you can have output isolation if you use an opto coupler in the feedback loop.
ian field
Joined Oct 27, 2012
6,536
Here is a PDF from TI about buck-boost converters.
Bertus
The circuit posted by the TS wasn't buck/boost - I'd start with a book that at least outlines the different topologies.
Can't remember if the book I'm thinking of includes buck/boost - but the TS has to start somewhere.
In any case, I think the job can be done without so much complexity.
bertus
Joined Apr 5, 2008
22,960
@ian field , The TS is showing an inverting buck-boost converter.
From the posted PDF:
In the schematic of the TS the capacitors are the wrong way around.
Bertus
yoshua habibnur q
Joined Apr 16, 2017
8
i choose this topology because the simplest one for step up and down dc-dc converter comparing with other topologies that i know (cuk, SEPIC ETC)
Bertus
right, but no matter i switch capacitor polarity,i see no different in simulation. does it really affect the works of buck-boost?
DickCappels
Joined Aug 21, 2008
10,661
I was surprised to see that Wikipedia calls the present circuit a buck-boost.
Buck–boost converter
One drawback of making the polarity of the output opposite to the input is that the voltage swing on the MOSFET and rectifier is almost double what it would be if the circuit had an output the same polarity as the input. Nothing wrong with 700 VP-P on the drain, but it makes driving the MOSFET harder and makes things a little warmer and more expensive.
If the output polarity were to be the same as the input then another inductor (or another winding on the same core) would be needed to be able to buck or boost depending upon the input voltage.
Yoshua, do you want the output to be the same polarity as the input or opposite polarity?
yoshua habibnur q
Joined Apr 16, 2017
8
i want same output as input, thus positive output.
DickCappels
Joined Aug 21, 2008
10,661
This topology won't do what you specified.
Vin = 300-340 Vdc
If you want the power supply to be able to accept voltages higher and lower than the output you might want to have another look at the Cük converter.
ian field
Joined Oct 27, 2012
6,536
Vin = 300-340 Vdc
What most people understand to be buck/boost topology, are more complex and can be a bit challenging.
The cheats way out is to keep the buck and boost stages separate - perhaps boost it to slightly above the required voltage and then buck it down to that.
Most mains SMPSUs with PFC use 2 stage conversion - The PFC stage is actually a flyback boost converter with no mains reservoir electrolytic. Most are followed by a second flyback stage with transformer output - it gives isolation and more or less fails safe. If the transistor in a buck regulator fails short circuit - it stuffs the input voltage straight through to the load.
