Hi all,
I'm trying to modify my bread maker to make it completely manual. For those who don't know, they essentially consist of:
- metal casing
- metal bread pan
- motor to mix and knead
- heating element to bake
- electrical circuitry and chips to control the programs, and the motor and element
In stock form, it has pre-set programs that run through a particular process, eg. mix for 2 min, knead for 20 min, let rise for 60 min, bake for 40 min etc.
What I want to is simply remove all programming circuitry, and add one switch the the motor, and another to the heating element. All I want to do is be able to switch the motor on and off, and the element on and off. I don't want any programming at all. Simply on/off switch for each.
The motor is done, I have already done that by simply connecting the power cable's neutral and active to the motor's neutral and active and putting in a switch. Easy.
But when I do the same for the element - as in connect neutral to one end of the element and active to the other, it heats up for about 2 minutes and then trips the circuit breaker. If I reset the breaker straight away, it will heat for a few seconds and then trip. If I leave it for a few minutes and then reset, it heats for a bit longer and then trips. It never trips straight away.
Any ideas on why this would happen, and how to stop it from tripping?
Thanks
- metal casing
- metal bread pan
Thanks
