Braking resistor question
Davor Krpan
Joined Feb 1, 2019
8
Braking resistor on AC servo motor driver is not working, and I cannot find power on it (It burned up), but it is 100ohm . Power on driver is 200W. Can I put 400w (100ohm) braking resistor on that motor?
wayneh
Joined Sep 9, 2010
18,168
Personally I'd use a big bright lightbulb. Instant feedback that it's working, very cheap, and purpose-built to shed the heat.
MaxHeadRoom
Joined Jul 18, 2013
30,813
Higher wattage is OK, as long as the resistance is no lower.
You can get an idea from the physical size as to the original wattage.
Max.
Ya’akov
Joined Jan 27, 2019
10,300
Is this related to your controller problem? Did you get that sorted?
