Thanks for your detailed answer!You are not understanding the concepts of discrete and continuous. I would suggest that you do some reading on scale types.
In the case of memory addresses, we are talking about discrete values. There is no space between address 123 and address 124. There is no memory address of 123.5, for example.
Temperature, on the other hand, is on a continuous scale. There is always space between the values of 123 and 124. There is a value of 123.5, for example.
You can see this - right? You understand the difference between discrete and continuous? If not, there is plenty of information available for you to read on that issue, but you have to actually search and do the reading.
Secondly what's confusing me how would for example a block ends in 123 and another block starts in 123?! It either starts or end in a specifi address.
But you didnt explain any thing you just said it's not taking place; why isn't it taking space?!I give up. Maybe someone else can succeed in getting this guy to understand, but I'm done trying.
