I design buck converter half bridge circut(for mmpt deign) .but this circut bottom Two opto gone suddently .what is the issue
How are the opto devices failing? Input side or output side? If it is the input side the circuit driving the LED is not shown. What is it? Reverse voltage to the LED, according to the data sheet, should not exceed 5V.
How is the 12V supplied to the bottom opto's?Thanks your support. opto output side failing suddenly . (only bottom both opto output side failing)
i attach schematic upgrade file. 12v bottom sulpay support smps. bottom side 12v smps output (gnd common)How is the 12V supplied to the bottom opto's?
