how to fix this, the hot-contact in the bottom of lamp socket
Hymie
Joined Mar 30, 2018
1,347
I’d try scratching the contact with a sharp tipped implement and maybe emery cloth; but it appears that the copper? coating has become tarnished. The bare metal may tarnish again quickly and require regular cleaning.
Remember to clean out any conductive debris that the scratching removes.
LAOADAM
Joined Nov 21, 2018
956
tried that way and its too soft to keep contaced when machine running.
27,436
I noticed on the image of the failed socket that there was also an indication of arcing at the rivet providing the connection to the shell. So even if you had repaired the center connection a failure was stil waiting in the near future.
MaxHeadRoom
Joined Jul 18, 2013
30,627
A problem I have with the ES type lamp holder, it can be wired in the unsafe mode, i.e. with the lamp screw thread live.
With the one I was always used to (UK), the bayonet cap, dual pin, it is not so prone when a lamp is inserted.
LAOADAM
Joined Nov 21, 2018
956
Its true, hope I can use another few years.
