Bottom Line Stalker fishfinder won't boot
BeetSweet
Joined Aug 6, 2017
7
When the power button is depressed, the LCD display shows the normal "Stalker" splash screen but doesn't continue to power up. The unit powers down as soon as the power button is released. I found a leaking 22uf capacitor near the 5v regulator that had leaked onto the circuit board but replacing it didn't help. There is a 5v test point that reads 4.26v. The regulator is a LM2931CT and it's "adjust" lead appears to be not used and I don't find any pots on the circuit board. There is 100uf capacitor near the regulator that looks normal so I didn't replace it.
I guess my question is: does the 4.26V reading indicate a problem?
DickCappels
Joined Aug 21, 2008
10,661
Strictly speaking (writing) the LM2931 does not have an adjust pin. It is fixed at 5.0V ±3.8%. It should not be reading 4.29V. Is anything getting hot, which would indicate faulty circuitry elsewhere is pulling the supply down?
BeetSweet
Joined Aug 6, 2017
7
BeetSweet
Joined Aug 6, 2017
7
The fixed versions of the LM2931 has 3 pins.
The adjustable version of the LM2931 has 5 pins.
Both the TI as ON datasheets will show the difference.
Bertus
I couldn't find any technical information on this. The company went out of business a few years ago. I took a pic of the board with the regulator being on the left side.DSCN1591[1].JPG
bertus
Joined Apr 5, 2008
23,001
Could you make a picture of the corner with the regulator and the small smd parts around it?
If possible so that we can read the values on the smd resistors.
(I know that I can take pictures with my S5 that are that sharp).
Bertus
BeetSweet
Joined Aug 6, 2017
7
Bertus
BeetSweet
Joined Aug 6, 2017
7
I tried the heat test. The regulator gets pretty warm where I have to remove my finger after about two seconds and the other chips do warm up but only enough to tell they are warm. The warmest other than the regulator is the large chip at the top of the board in the first picture. It is a Siemens SAB 80C535-N.
DickCappels
Joined Aug 21, 2008
10,661
Regulators can run hot and still be fine -the maximum junction temperature of the die in this one is 150°C.
One test of the regulator that you might be able to perform is to measure the voltage between the output and the reference pin. Did you check the incoming power supply to make sure it is ok.
And while at the power supply connection, you can measure the input current and see how that compares to the label or manual if either is present.
