Boosting 0..2.5V to 0..10V using an opamp
Status
Not open for further replies.
Mech_Demon_A
Joined Aug 15, 2024
I am currently working on a project, where i need to boost dac output signal from 0..2.5V to 0..10V. I know the general rule on how to do that, but i am in the much dark about the specifics, for ecample what value of my resistors should be while maintaining R2/R1 = 3 ratio; what other components should i add before opamp, maybe some resistors, capacitors etc.
Any insight would be much appreciated.
PS. Scheme shown in the picture below is my base for the needed result, wich I modify in order to find the solution to my problem.
35,281
Your resistor values are way too low. Try values that are 1000 times or 10000 times larger.
The first question you need to ask is what is resistance of the load?
With a load of 1 Ω you are asking the op amp to deliver 10 A at the output. That is 100 W!
That is not going to happen.
Mech_Demon_A
Joined Aug 15, 2024
Yes, I get that these values are not realistic, it is only to show the relation of R2 to R1, wich must be 3, so that i get a gain coefficient of 4 and thus boost 2.5V up to 10V.
35,281
Yes, and so my R2/R1 ratio must be 3, precisely why I've chosen 3 Ohm for R2 and 1 Ohm for R1 resistors for now.
Precisely, not.
3000/1000 + 1 also gives a gain of 4.
I have not indicated the power required to drive R1 + R2 at 10 V. (The answer is 25 W.)
Also, will the op amp work down to 0V input on a single supply?
panic mode
Joined Oct 10, 2011
5,438
And it goes further... do need to add some output protection? Say 47 ohm resistor connected to output. The feedback resistor can connect after that to compensate for voltage drop
35,281
Here are some guidelines and a rule of thumb.
Know the input and output impedance of the amplifier and the load. The output impedance of the amplifier should be 10 times lower than that of the load,
For example, suppose your amplifier has to drive a load of 10k Ω resistance. Then the output impedance should be 1 kΩ or less.
Bordodynov
Joined May 20, 2015
3,432
The model of this 3288RT operating system is disgusting. It is designed to calculate low-signal analysis. For example, filters. It does not model the load capacity of an operational amplifier well. For some reason, this amplifier is persistently offered in educational institutions. Moreover, Google does not know him.
Here is an example of a circuit calculation showing how the maximum output voltage varies depending on the load value. This is because of the current limitation. I have used a transistor model of an operational amplifier.
28,525
Until the TS can also tell us the current required by the load that needs an input of zero to ten volts there is no way we can provide better than a good guess.
Before we can tell how to "get there" we need to know where to go. Until the requirements are stated adequately there is no way to advise as to the way to meet them.
28,525
Visiting post#1 again, I see an apparent error:" boost dac output signal from 0..2.5V to 0..10V. "
I am now assuming that the TS meant "10.0 volts".
It seems that nobody else caught that.
Then, addressing the comment about the LM358 device, it has three important considerations in it's favor.
First, it is commonly available, being produced by several different manufacturers,
Second, it is cheap, being one of the least expensive op-amps in an easy to handle package.
Third, it is more forgiving of poor handling practices and assorted connection errors than many of the much better products available.
In addition, it's various weaknesses can serve to show students that real devices are not the same as the ideal ones used for teaching principles of how circuits work. There is usually a fair distance between theory and actual practice, at least in much of engineering.
ericgibbs
Joined Jan 29, 2010
21,637
What the TS is clearly asking for is how to boost a signal varying from 0v through 2.5V, to an output of 0v through 10.0v.
E
28,525
E
I understand that!! My point was that there was a typo in the first post that was never addressed. Nobody mentioned that point.
And I don't think I saw any response as to what the load properties were.
Status
