Thank a lot for this circuitA voltage limit where it cuts off if the voltage exceeds that of a connected devices' maximum voltage?
That is usually part of a voltage regulator circuit. Is there any particular circuit you are considering?
The circuit above automatically shorts out the power supply and blows the fuse if the maximum safe voltage is exceeded.This kind of circuit is referred to as a crowbar circuit. There are other techniques as well.
Im protecting a class d amp so i wanted a full cutoff of power when the voltage increases anything over 24vThe scheme used to protect against an over-voltage condition depends a whole lot on what sort of system is involved. The arrangement for disconnecting an over voltage in a mains power system is quite different from the one protecting against alternator regulator failing in a car, and both are quite different from the one protecting equipment connected to an antenna from excess voltage.
So without more details there will be no answer!!
The power inputAre you protecting the power input to the amplifier from an over voltage situation on the power supply, or protecting the speakers from an overvoltage situation on the amplifier output?
I got this tru rated pc psu but im ussing a boost conveter to boost the voltage tp 24v so i was worried the boost comverter might fail and send more than 24vWhat kind of power supply are you using where you are worried about over-voltage?
We have no hint as to what the "tru rated pc psu " is or what voltage it supplies or it's current capability. Then there is some sort of boost converter to raise an unknown voltage up to 24 volts.I got this tru rated pc psu but im ussing a boost conveter to boost the voltage tp 24v so i was worried the boost comverter might fail and send more than 24v
Oh sorry its a Corsair cx 750 bronze im using the 12 v on itWe have no hint as to what the "tru rated pc psu " is or what voltage it supplies or it's current capability. Then there is some sort of boost converter to raise an unknown voltage up to 24 volts.
The circuit shown in post #3 will provide the requested protection, most likely. GOOD LUCK.
Does it have a -12V?Oh sorry its a Corsair cx 750 bronze im using the 12 v on it
Yes but i dint know the useDoes it have a -12V?
You could get 24V from the +12V and -12V outputs. However, the -12V might have a limited amount of current available.Yes but i dint know the use
Really sorry for not providing adequate information about my concernWhat I think is being done is that a DC power supply ( Corsair cx 750 bronze ) is being used to supply 12 volts to a circuit that boosts it to 24 volts, to feed a "class D" amplifier that is intended to operate from 24 volts.
The TS "does not know how to use" the negative 12 volt output from the power supply.
A great deal of thought has been wasted, it appears, because the TS did not provide enough information with the initial question.
"How to use the negative 12 volts and the positive 12 volts to power an amplifier that requires 24 volts power" would have lead to a suitable answer directly.
my-12v rating is only 0.3A while tge +12 can go upto 50A and i need a 24v 5A to power my amp, so I don't think this would work?You could get 24V from the +12V and -12V outputs. However, the -12V might have a limited amount of current available.
True.my-12v rating is only 0.3A while tge +12 can go upto 50A and i need a 24v 5A to power my amp, so I don't think this would work?
