Boost converter with MAX1771
UrsusDominatus
Joined Dec 15, 2017
Can anyone tell if my converter works right? It generates right voltage and almost does not heat, but I don’t understand why in close state of MOSFET current through inductor increases (channel 3) and why there are several voltage peaks on drain (channel 1)? How can I suppress this peaks, or maybe it is ok?
bertus
Joined Apr 5, 2008
23,012
How much is the input voltage?
What should be the expected output voltage?
Based on the schematic I am calculating an output voltage in the range of 180 to 230 Volts.
Bertus
UrsusDominatus
Joined Dec 15, 2017
According to this page the MAX1771 is designed to have a max output voltage of 100 Volts.
https://para.maximintegrated.com/en/results.mvp?fam=stepup&1395=65
If you want to boost-up to 200 Volts better use the MAX17597:
https://www.maximintegrated.com/en/products/power/isolated-power/MAX17597.html
Bertus
Thank you for answer, but i haven't found any restriction for output voltage in datasheet, i think output voltage limited more by external switch, rather than ic itself, besides, as far as i understand, MAX1771 works fine, some problem happend between inductor, diode and MOSFET
