Boost converter turn-off time
anhnha
Joined Apr 19, 2012
904
For the boost converter below operating in DCM mode, the voltage conversion ratio is calculated as follows:
M = V/Vg = 1 + D1/D2
where
V, Vg are output and input voltage respectively.
From the formula, it is clear that the conversion ratio doesn't depend on D3. So, is there any requirement for D3 here?
ronv
Joined Nov 12, 2008
3,770
Just that the lower the voltage drop the more efficient the conversion.
And of course the voltage and current ratings must be high enough.
dl324
Joined Mar 30, 2015
18,336
How does it depend on load current?
When the voltage at the cap drops below the target voltage, the switch needs to turn on. A higher load will discharge the cap faster, making it necessary for the switch duty cycle to be higher.
anhnha
Joined Apr 19, 2012
904
Can I reduce switching frequency instead of increase duty cycle? I think it is the same here.
