Boost converter small signal model error
AMANORA
Joined Sep 21, 2021
9
So I was simulating a boost converter on plecs, wanted to calculate Gvd. Firstly I solved the model by hand and drew the bode plot, then I drew the schematic on plecs, made sure of the values and parameters are equal to what I designed by hand. my issue is that my dc gain that I calculated by hand is twice that got drawn by plecs. I made sure of my calculations by referring to this to make sure that I made no mistake. my calculations are equal to the model presented here.
Post image
Model
this is the schematic on plecs. D = 0.5
Post image
Schematic
This is the average Dc output voltage.
Post image
And this is the bode plot of the converter.
Post image
Gvd
As you can see, the dc gain is about Vinput/(1-D), instead of Voutput/(1-D).
I really hope that this is not a dumb question and itsnot a silly mistake of mine since I spent too much time working and searching what did I do wrong :S.
Irving
Joined Jan 30, 2016
5,144
Your FET is drawn upside down....
Here's the LTSpice equivalent, D = 0.5, f=100kHz
I'm not sure how you're generating your bode plot
Close up of 1 cycle @ steady-state
AMANORA
Joined Sep 21, 2021
9
Hello Sir, thanks for replying and I hope I am not wasting your time.
Plecs has an intrinsic small signal model generator analysis. My time domain analysis lies inline with my hand written calculations, but the bode plots are not..
I tried another schematic which is already drawn in my book, the issue is always the Gd0 or the low frequency gain, its always lower that whats expected to be.
Again thanks for your time :).
Irving
Joined Jan 30, 2016
5,144
Understood, LTSpice also has a small signal analysis capability. Confusingly you talk about DC gain but a Bode plot is an AC analysis. So what are your input and output signals?
Hughes4
Joined Sep 22, 2021
Pleased to see your question as I think I have the same question, I am also confused and in need of light on this same issue. Need help.
<Mod: link deleted.E>
AMANORA
Joined Sep 21, 2021
9
Hi, sorry for the confusion, I meant with the dc gain is that low frequencies gain, its written in books as Gd0. I just fixed it and it was a pwm issue. Thanks for yout time :)
AMANORA
Joined Sep 21, 2021
9
Hi budd, can you please email me at <Mod: Deleted email address, avoid Spam.E>
Irving
Joined Jan 30, 2016
5,144
No problem.
BTW, that other message was an advertising Bot, not a real person...
