Boost converter problems
Mohamad Tarabah
Joined Jul 4, 2016
54
Hi everyone, I've recently tried boost converters with 3.7v li-on batteries. It will boost the output until you put some load on it, 1k ohm will drop the voltage terribly. So now I've tried it with a power supply. It's not boosting at all. I'm using a 555 timer with 10k var and 4.7k fixed resistor and 10nf and 100nf caps. The boosting part is using 2000uH inductor and shottcky diode with BC337 transistors ... Never mind about the schematic. Whatever I change I get same results. Any help ? I can buy boosters but I hate when I fail making my own stuff.
38,946
What are the output voltages you are measuring with and without a load?
You 555 is running at a low frequency and the inductor may be saturating.
What is the current rating of the inductor?
Try reducing the 100nF cap to 50nF or less and see if that changes anything
bertus
Joined Apr 5, 2008
23,031
In the openings post you state that you want to boost an 3.7 Volts Li-ion battery.
In the schematic you show 5 Volts.
The minimum voltage for a bipolair 555 is 4.5 Volts, so the Li-ion battery will not work.
Bertus
Alec_t
Joined Sep 17, 2013
15,167
..... and Vgs(thr) for an IRF540 can be as high as 4V, so the FET may not be turned on fully, or even at all; especially as the bipolar 555 output voltage is always a volt or more below the supply voltage.
Mohamad Tarabah
Joined Jul 4, 2016
54
Ok, I've been working the last 3 days on converters and now I think we should use PCBs instead of building converters. I've seen enough fails for now, time to pay some money
