Boost converter: 555 timer heating up, problem with operational durability.
Avid
Joined Jun 29, 2018
i was trying to drive a boost converter of with 60mhenry, 1000uf, 2n7000 mosfet, 2n4148 diode, with frequency of 2khz from a variable duty cycle 555 timer pulse generator, 12v power supply to produce between 15 v and 24v based on duty cycle adjustment. the pulse generator and converter are connected to the same power supply and ground.
MOD: Deleted multiple copies of the same image.
bertus
Joined Apr 5, 2008
22,995
Did you make a typo?
The 2N4148 is a thyristor and not a diode.
The 1N4148 is a small signal diode.
You will likely need a more powerfull and faster diode in that place.
A resistor of 22 to 100 Ohms between the output of the 555 and the gate of the mosfet might reduce the heating of the 555.
Bertus
Alec_t
Joined Sep 17, 2013
15,155
Simulation says the average power dissipation in the 555 should be less than 50mW, so if your 555 is over-heating you have either a circuit error or a faulty/fake 555.
Avid
Joined Jun 29, 2018
Bertus
sorry, it is 1n... not 2n....
thanks
