Book or course to learn electronics
Rufinus
Joined Apr 29, 2020
325
Hi. I know basics of electricity. Ohms law, how behave resistors, caps, coils... But I want to learn analog electrnics this summer.
Could you recomend me good books or online course? I´m doing for hobby, just for star designing my own circuits.
Thank you
SamR
Joined Mar 19, 2019
5,542
Some will say Grobb, Malvino, or Floyd. My preference is Boylestad's Introductory Circuit Analysis. Older editions but still the same theory is cheaper. Preferably in Very Good condition (like new). Might be found online as a free PDF. There is also a lab manual to accompany it. Excellent grounding in DC and AC theory. Also, his Electronic Devices and Circuit Theory and its lab manual for solid state components as a follow on. GetTextbooks.com is a valuable resource when searching for used books of any kind.
28,434
A college area books store that has the previous generation of text books can be a good source of less expensive books. AND NONE of the basic stuff has changed in the last 50 years. AND NONE of the new stuff is basics, anyway.
Rufinus
Joined Apr 29, 2020
325
Thank you. I´ll check it out. And yes, I preffer the old ones.
What is the thing/problem of the earth grounding??
MaxHeadRoom
Joined Jul 18, 2013
30,854
It is not the earth grounding, per-se, but the seemingly indiscrimanent use of the symbol across the board,
Unfortunately it has become the practice by many to use it, whether or not the circuit power common is meant to be at GND potential or not.
Which unfortunately, makes it meaningless! :confused:
Ian0
Joined Aug 7, 2020
13,294
Maybe Messrs. Horowitz and Hill had a power supply which had 0V connected to the protective earth, and they used it for all their circuits. Then, I suppose, the book is correct.
You are right that they should have used the correct symbol, but it doesn't invalidate the information that the book is intended to convey. If the book were about designing and making an electronic product to sell, then a thorough coverage of earthing and all the safety standards would have been essential.
WBahn
Joined Mar 31, 2012
33,263
Thank you
Be sure to be realistic in how much you expect to learn about analog electronics on your own over one summer. It sounds like you are starting from the level of understanding that, in an engineering curriculum, would usually be obtained in a Physics II course on electromagnetics. You've learned about the basic components (resistors, capacitors, and inductors), their constitutive equations (such as Ohm's Law), and probably how they combined in series and parallel and how to analyze the simplest circuits that involve them. That's basically the starting point for a Circuits I course, where you would learn more powerful techniques on how to analyze more general circuits restricted to these same components. You would still have a few more semester-length courses before you were really getting into the meat of analog electronics.
So you might try first narrowing the focus by deciding what it is you want to actually be able to do by the end of the summer. Pick a project that you want to be able to tackle, for instance. Then describe that and we can better discuss whether that is practical and, if so, what some good paths towards it might be.
MaxHeadRoom
Joined Jul 18, 2013
30,854
I didn't intend to mean the contents were invalid, just that I would have expected that circuit diagrams of the general nature would have indicated the local common of the supply, as the circuits illustrated do not really require it.
Also I could not find a page that described circuit device symbols either.
SamR
Joined Mar 19, 2019
5,542
Here's another one. Very broad coverage with some "lab" projects included. It is heavy on math but simple algebra for the most part. Not much discount for very good examples so might as well buy it new from Amazon. From John Wiley & Sons press and up to their usual level of excellence. I seem to remember a workbook for it as well but can't find it... 3rd Edition in very good condition also available and even cheaper!
metermannd
Joined Oct 25, 2020
472
One of the channels I'm subscribed to on YT is Mr. Carlson's Lab, and at the end of each of his videos he mentions a course he offers. Just mentioning it FWIW.
28,434
I just came across the 2006 version of the ARRL "Radio Amateur's Handbook", which appears to have a vastly larger section aimed at technical education then previous or later versions. So if the TS can find one of those 2006 copies used, it could be very educational.
