board to power on/off my audiophile Hifi system
thor21
Joined Sep 29, 2024
435
1)
Does it make any sense to use 4 pole relay
and connect for L - two poles together (to minimize resistance),
same for N.
2)
Also amp spec says:
This unit is supplied in the U.K. with a mains lead fitted with a moulded 13 amp plug.
250 watts per channel into 8 Ohms
Power Consumption 1200W
Can I use relay
Poles4
Rated carry current10 A
thor21
Joined Sep 29, 2024
435
@crutschow
dont wanna use device that input noise ... i have separate 230V circuit from CB dedicated for audio and dont wanna run on it any chinese device as these sockets.... just one to be able switch L/N on that circuit with mechanical relay.
38,926
@crutschow got your point but i liked the idea that Omron is really great quality relay which costs like whole wifi socket itself.
Sure i will have to add another electronic to control that relay... but should be fine.
if someone can double check and confirm #121, so can order relays,
https://forum.allaboutcircuits.com/...my-audiophile-hifi-system.207798/post-2007186
Okay, I see you are apparently a belt and suspenders type of guy.
Yes the relay and configuration in post 121 should work fine.
thor21
Joined Sep 29, 2024
435
@crutschow thanks
well i think i am done here, out of the energy, ordered mentioned 10A ; 2 poles relay and lets see...
For that line they state Contact resistance same for L1, L2, L4... hopefully it will be fine.
Maybe in case i switch both L, N ... in case of storm etc... device will be also protected. No idea how relay behaves in case of storm and issue light building hit by thunder...
thor21
Joined Sep 29, 2024
435
Only if the transient voltage is below the spark-gap voltage of the open contacts separation distance.
and how to find out that?
Also i think in scenario as mine ie i have Live, and Neutral is crossed(connected) to the ground;
I can only switch on/off Live only, bc of safety.
38,926
dont get it ..
You'd have to apply an increasing high voltage from the wiper to the NO contact to determine the arc over voltage.
Have to have a high voltage source to do that.
You might consider adding a transient suppressor outlet to your system (example below).
thor21
Joined Sep 29, 2024
435
Hi i can confirm it works with 2 omron relays flawlessly. Currently controlling DAC.
Next step - utilizing second relay - to control Amp. Than some proper box, cabling.. And securing....
The small board with blue relays is zigbee module powering on / off omron relays, bc of the smart home automation inside home assistant.
Thanks all.
