block diagram
uppi_777
Joined Feb 26, 2018
70
  • Using some components i would like to draw a block diagram to fulfill the following requirements
    Vin=230VAC; Vout1=48V 300W DC; Vout2=3.3V 100W DC
    Could someone please help me out to draw a block diagram
uppi_777
Joined Feb 26, 2018
70
The 48V DC load periodically (frequency is 1 Hz) switches on and consumes 20 A current for 100 ms.
The primary energy source is 270 V DC.
A block diagram with black boxes and components necessary (converters, inductors, resistors, capacitors, switches etc) is expected.
2.Using some components i would like to draw a block diagram to fulfill the following requirement
  • Vin=230VAC; Vout1=48V 300W DC; Vout2=3.3V 100W DC
jpanhalt
Joined Jan 18, 2008
11,087
How about you showing us your efforts on this assignment? Then we can work on that.
EDIT: Sounds like homework
jpanhalt
Joined Jan 18, 2008
11,087
Mods: Please move to homework
@uppi 777
Generally on this forum, we do not do your homework. However, if you will show an honest effort, there is almost unlimited help available. So far, you have shown nothing.
Reloadron
Joined Jan 15, 2015
7,977
You will find my answer where you asked the same question in another forum.
"The answer is in what software you plan to use to create the block diagram. A simple Google of "power supply block diagram" will bring you up several dozen images but without knowing what software you plan to use to draw a block diagram it is about impossible to answer your question. A simple block diagram can be done using MS Paint".
Since this is an assignment I suggest you start with the link I provided. The way assignments work is you get help for showing your efforts.
Ron
