Block diagram for a 24 hour clock
Banjo 3100
Joined Mar 21, 2012
2
I need to design a block diagram for my 24 hour clock but I was never good at designing them :( My circuit schematic is uploaded and my attempt at the diagram is as follows:
Crystal oscillator --> Counter --> Decoder --> 7 segment display (with a feeder called debounce switch going tinto the counter)
If anyone could help I would be very grateful, thanks :)
Wendy
Joined Mar 24, 2008
23,869
Something you might think about, AAC has a local system of attachments and albums. If you followed my links you will have seen examples of both.
There isn't any mystery about drawing, and pencil is OK. In my view reset is a subsystem of the control circuitry, which I drew on the digital clock thread. The digital clock has a different block diagram, I wonder if you even looked at it.
I tried using the img link on your site, it was way too big at 1598 pixels. Using M/S Paint, which is also what I use for my drawing, I brought this down to 800 pixels wide.
If you look you will note some differences how we approached our drawings. You did not segregate the systems very well, think of signal flow going from left to right or top to bottom (as you have done), but separate them. It is, after all, a block diagram. Each system is a block. Your diagram resembles a flow chart, but you still have not delineated each section very well.
panic mode
Joined Oct 10, 2011
5,438
there are RTC chips that provide stable clock output (such as 1Hz) but i don't think any of them would do 24h. you can add counter(s) to get any period you like but why not use MCU for this? this is exactly kind of job programable chips are good for.
is there a chip with an output every 24 hrs?
The DS3234 RTC can give you an interrupt evey time the hours, minutes and seconds in it's clock match the predefined values you select.
So, if you do not mess with the clock in the meantime, it should give you the interrupt every 24 hours.
