Let's not get started with gravity.Unfortunately, obscurantism is very widespread nowadays. In my countries, there are even people who argue that gravitaty pushes things apart, not pulls them together![]()
nonsensical quackeryI have a book called "the Final Theory of Everything". The authors theory that gravity does not "attract" but objects are growing in size so that instead of an object falling to "earth" the earth is actually growing in size and meets the object in free fall. Lots of other stuff he has in there, makes for an interesting read if you have nothing else to do!
To complete the old joke all you have to do now is move to Oklahoma, and it will be a very long life indeed.I've grown shorter living near my wife, but doubt I will live longer. It might seem longer...![]()
It could be caused by phase changes. Or new nuclear reactions that were not previously possible, given the much higher pressure and temperature......The supernova explosion must be caused by the conversion of thermal energy into a sufficiently large amount of kinetic energy so the mass can be expelled at escape velocity. From my research on the supernov
Either way, if you get hit by a falling piano, the result is the same.Let's not get started with gravity.
The black hole itself is not visible, however the radiation from the accretion process can be observed.So if they cannot see the lunar lander, using the Hubble, then how can you see a black hole 1.8 billion light years away, that is approximately the size of the sun.
The accretion process around a black hole can generate a lot of radiation which can equal or exceed the intensity of the original star that formed it.How can you determine the effects of a black hole 1.3 billion light years away, that has a diameter of the sun when the Hubble cannot see the lunar lander. Also, the lunar lander is on the moon.
The radio waves are generated by the accretion of matter around an existing black hole.So a black hole come from one of those radio waves? HA Ha
First of all, the distance is much less than 1.3 billion light years.Be serious, radio waves 1.3 billion light years away, from the earth, being detected on the surface of the earth, using an interferometer. What happens if you were to fart, during the experiment. Do you realize how ludicrous that sounds?
