Black box pill reminder
mikeinkaty
Joined Oct 21, 2013
13
anyone care to sketch out this circuit for me?
I need a box with a push button that will start squacking (beeping) 24 hours after I last push the button. Don’t need it to allow different intervals. Just 24 hours. No flashing lights. Pushing the button turns off the beeps and starts another 24 hr cycle. Don’t need it to tell time. That should be simple but I can’t get past the 555 timer curcuit.
Such would keep my doctor happy!
Any help appreciated. I can fabricate everything - just need a circuit diagram.
Mike
34,810
I can do it with two off-the-shelf chips.
If it were me I would do it with one MCU chip and 1-second accuracy.
How much timing error can you tolerate? That is, do you care if it is 5 minutes early or late?
BobTPH
Joined Jun 5, 2013
11,515
There is an inherent flaw in your logic. Each day, unless you happen to push the button immediately, the time for the next alarm will advance by the length of time that you have missed by. A better solution would be an alarm that goes off at the same time every 24 hours.
Bob
ebeowulf17
Joined Aug 12, 2014
3,307
Number Twelve is busy with winter chores...wagging a paint brush, checking noises under the car...things like that.
That seemed like a really, really random interjection until I realized you had been tagged by killivolt a few posts earlier!
GopherT
Joined Nov 23, 2012
8,009
Mike
What's wrong with the alarm on your phone?
Set it to go off every morning at x:yy
Or, set your Samsung TV to turn off at x:yy and then turn on at x:yy (you can select the turn-on channel -use QVC as the channel so you'll be sure to get up and change it and take your medication.
BobTPH
Joined Jun 5, 2013
11,515
Whats wrong with the phone is that it goes off wherever you are, unless you are carrying all your pills with the phone, the alarms will be useless. I had actually set that up on my phone, and, more often than not, it did not help me take my pills. A back burner project for me, when I find the time, is one that will sit next to the pills in the bathroom, detect that someone is there (via light most likely) and beep if I haven't taken my pills for that day.
Bob
mcgyvr
Joined Oct 15, 2009
5,394
Bob
Sounds like what you really need is a reminder to take your pills with you when you leave your house..
Of course if your phone alarm goes off and you aren't there then simply set another alarm for when you think you will be home..
OP just requested a 24 hour timer with no other real stipulations..
$29 on an Alexa Dot or Google Mini also gets you pill reminder skills/timers/text messaging alerts,etc... too..
ian field
Joined Oct 27, 2012
6,536
Bob
Or a common or garden discount store travel alarm clock IOW.
spinnaker
Joined Oct 29, 2009
7,830
Bob
Use a little common sense and carry your medication with you if you need to take it through the day. :confused:
BobTPH
Joined Jun 5, 2013
11,515
Who said anything about takings meds through the day. I take mine all at once, and yet I still cannot seem to do it reliably.
I am not the OP by the way. I was just weighing in on my experience with a suggested solution. It did not work for me.
Bob
spinnaker
Joined Oct 29, 2009
7,830
Bob
Then your phone alarm wouldn't be going off in the middle of the day then would it?
