BJT voltage gain
hamza324
Joined Jul 10, 2011
33
hi ....
I was reading through my book and could understand the difference between "terminal voltage gain" and "overall voltage gain"
BJT single stage amplifiers
Jony130
Joined Feb 17, 2009
5,601
Can you show as the diagram or the text from that book.
General speaking when we treat the amplifier alone the the voltage gain is equal
Av = Vout/Vin
But if we consider the influence of the source resistance and input resistance of our amplifier we get the overall gain.
Overall gain = Vout/Vs = Vin/Vs * Vout/Vin = 0.5 * 100 = 50V/V
lazukan
Joined Mar 29, 2011
5
hi ....
terminal voltage gain refers to V (collector ) / V ( base)= Beta
Overall voltage gain refers V ( out) / V( in)
It is the matter of the fact that at which terminal or branch you take the measurements
Correct me if i am wrong
Lazukan
RLC
Joined Jul 20, 2011
13
Terminal gain refers to β gain (Hfe) which we can directly measure on
Multi-meter.
While overall voltage gain refers to, taking gain with taking source Impedance and Load impedance into consideration
Adjuster
Joined Dec 26, 2010
2,148
β is a measure of current gain: it is not directly related to voltage gain, although due to its effect on input impedance it does make a contribution to overall voltage gain.
