For a very long time I've had trouble understanding and figuring out the REAL characteristics of BJTs. Sometimes I hear them called voltage amplifiers, current amplifiers, switches, voltage-controlled resistors, etc; etc; etc;
I'm assuming that all of these are true, but each one requires a different perspective of the same event. Could someone please explain, in detail, (even at the physical layer if possible) the different perspectives, and why/how each works?
For example, placing a resistor at the base will decrease the current flowing through it, and thus will reduce current through the Collector/Emitter. HOWEVER, in reality, you're really just changing the voltage at the base because you're dropping a certain amount voltage across the series resistor. (I'm assuming).
I think, probably, the best model for me would be the voltage-controlled resistor. Given the voltage V at the base, what would the effective resistance be across the Collector/Emitter? Would the equation look something like x/V? Where x is some real number? Or like x/V^2? x/V^y? I have really no idea.
Also, to calculate the actual voltage at the base with a series resistor, would you use the same concept as described in another of my threads?
http://forum.allaboutcircuits.com/showthread.php?t=70009
My end-game is to be able to design digital logic as efficiently as possible with BJTs, Diodes, and resistors. I don't want to use cut-and-paste logic gates, I want to know the highest-value resistors I can use and such, to minimize energy waste. Also, in general, I like to analyze the next 100 steps before taking just one.
