Bit field defines for setting CLKPOL and CLKPHA to zero
yef smith
Joined Aug 2, 2020
1,479
Hello nsaspook,So in order to change this property given the two tables you shown I need to write it as bellow:
Code:
SPIDRV_HandleData_t handleData;
SPIDRV_Handle_t handle = &handleData;
handle->SPIDRV_ClockMode=spidrvClockMode0;
Correct?
Thanks.
I would assume you would need to use the proper API calls to get the actual handle and to update SPI comm properties.
