Bistable Memory Elements
mghg13
Joined Jul 17, 2013
62
Hello, I am a student in electronics and I need some info for an homework on digital electronics
Can anyone tell me what is meant by 'bistable memory elements' ?
What is it made up of? I mean, from what basic digital electronic components is it made. How is it used in digital systems? Some examples where it is used??
And what is meant by the term 'bistable' ? Are not everything in digital electronics 'bistable' (since we can have only 0 or 1)???
Are there memory elements that are not 'bistable'?
I just need some general info about these things so that I know on which topics should I focus.
Thanks
22,111
Bistable refers to a device with two (bi-) stable states. This is a flip-flop.
Monostable refers to a device with one stable state. This is also called a One-Shot.
Astable refers to a device with no stable states. For a binary device it oscillates back and forth between 0 and 1.
mghg13
Joined Jul 17, 2013
62
you mean to say that all the flip flops (JK, T, D) are the bistable memory elements?
Austin Clark
Joined Dec 28, 2011
412
And what about memory elements that are not bistable?
I don't think there is such a thing. Unless, perhaps, you count DRAM, which must be periodically "refreshed" to maintain its memory. This is close to a monostable, but monostables I've seen can only be re-triggered after they've already decayed into their default state.
33,199
A monostable circuit is most definitely a memory element -- it's state is a function both of it's present inputs and its history. For its history to affect its state, it has to have some way of remembering that history.
The classic 555 MMV circuits are retriggerable. If you want an output pulse that is shorter than the input trigger pulse, you need to put some kind of an edge detection circuit on the trigger input.
Most DRAMs would not be considered monostable because the value stored in them decays whether that value was a HI or a LO, hence neither is stored in a stable fashion without refresh.
A schmitt trigger is, technically, a memory element in that its behavior (and output) is dependent on its history. But that remembered information is not accessible directly from the output (though it can be inferred very easily) so it is pretty much never thought of as being a memory element. If it were, it would be classified as an unstable memory element because in either output state it will remain there indefinitely only as long as the inputs continue to reinforce that state.
mghg13
Joined Jul 17, 2013
62
Thanks for all your replies!!!
Now I would like know what are 'finite state machines' and how bistable memory elements are used in these? Give some examples
absf
Joined Dec 29, 2010
1,968
Look at Vol. IV (Digital) Chapter 11(sequential circuits counters) above you. There is a whole page describing 'Finite State Machine'...... It's a nice read.
Allen
