bipolar square wave
Steevefrench
Joined Sep 7, 2020
Good day, thank you for time.
I am learning electronics, and decided to build things as a hobby to learn. I am presently learning about mosfet. (and how to use my oscilloscope without sparking things...)
I have look many places and read as much as I could, learn a ton a long the way, but I am presently stuck in my quest. Either the explainations are too advence for me to understand at this present time, or they do not apply to what I am trying to make.
I am looking to build a system with the following specs:
Using a PWM module example :
https://www.droking.com/pwm-module-...table-module-lcd-display-1hz-150khz-pwm-board
I would like to generate a bipolar square wave.
With relay it would be easy as there is a NO and NC contact, is there a way to accomplish this with mosfet? is there a NC mosfet?
so in summary :
PWM module generates a unipolar square wave that could be transform into a bipolar square wave, the voltage and amperage of the bipolar square wave would be max 30vdc and 10amp.
Thank you for your assistance. :)
