Bipolar high voltage +/-100V@2A for Ultrasound Pulser.
Status
Not open for further replies.
PattPatt
Joined Apr 3, 2025
5
I’m designing an ultrasound pulser-receiver using either the HV7360 or HV7361. Both components can handle ±100V and outputs can source and sink up to 2A current. However, I’m struggling to find a suitable power supply that can deliver ±100V at 2A.
I´m not a experienced hardware designer, so I searching for commercial AC/DC or DC/DC ±100V converters, but none seem to meet the 2A requirement. I also reviewed the HV7321, HV7351, or STHV748 demo boards, but they don’t explain how to generate the required bipolar high voltage.
Could you suggest a suitable solution?
Any help will be appreciated.
PattPatt
Joined Apr 3, 2025
5
Thank you MrChips for your reply.
The ultrasound transducer need to be applied a rectangular +/-100V 1MHz burst (configurable from 1 to 16 pulses). 200Vpp. This burst will be applied once every 30 minutes.
PattPatt
Joined Apr 3, 2025
5
Do you mean something like the attached sketch? Would there be any issue connecting the resulting reference to the ground of the rest of the circuit? Could you please guide me a little bit?
35,306
What you have drawn is correct. Make certain that the power supply is floating, i.e. there is no galvanic connection to line voltage or earth ground.
Status
