BioSonic UC100XD Ultrasonic Cleaner
Frank_SFL
Joined May 12, 2021
17
Hello Everyone,
Not sure if anyone can help on this one, but I will give it a try.
I received a BioSonic UC100XD (Coltene Whaledent) Ultrasonic Cleaner from a friend.
He told me that it would blow the fuse when he turned it on.
So I took a look, and found that one of the ceramic transducers that are epoxied to the bottom of the tank was pretty much toast.
The other one looks to be intact.
Unfortunately, I can't read any information that was on the transducers with the exception of "Morgan 090205" which I assume is the manufacturer and date.
That ceramic transducer will need to be replaced.
The problem is....I am not sure what to get to replace it. I know it is a 50mm ceramic, but beyond that, I am not sure. I am including a couple of photos to see if anyone has any ideas.
The part number on the circuit board is 05631 Rev 0.
I tried to provide as much info as I could.
I appreciate any help/guidance that folks would have.
Thanks!!
Frank
Frank_SFL
Joined May 12, 2021
17
Thank you for the quick response!
There were other numbers on it, however, the crack ran straight through those numbers and obliterated them.
The other transducers numbers were so faded, I couldn't read them.
Thanks again!!
