Bike powered Dynamo phone charger
Milkgod
Joined Mar 9, 2017
21
I'm trying to keep the circuit simple since I struggle with electronics. Here is a link to the project I'm using as a starting point I will also attach an image of the basic circuit.
I plan to use a 12v 100rpm DC motor or 24v depends which I can obtain easily.
I was going to use a switching voltage regulator module: LM2576 or LM2596 or mp1584.
This is going to output to a wirless charging coil instead of the USB thats in the diagram.
I've attached the image of the circuit that I'm basing the project off.
II know that the LM modules have a potentiometer to vary the output voltage, no idea how the MP1584 does it.
Is there a way to control the amperage that this will output? I'm trying to get 1Amp at least.
wayneh
Joined Sep 9, 2010
18,184
Yes, the load determines the current draw from the 5V source. That is, the load controls the maximum current. If the generator cannot keep up with the current demanded by the load, the regulator voltage will probably sag.
Milkgod
Joined Mar 9, 2017
21
Sorry what do you mean the regulator voltage will sag?
wayneh
Joined Sep 9, 2010
18,184
If the load exceeds the capacity of the system, something has to give. My guess is that the first thing to fail will be the voltage regulation. The data sheets for the regulators probably address what they do when overloaded.
