BiCMOS vs CMOS for Temperature Sensing
paddynbob
Joined Oct 30, 2017
25
Hey guys!
So I'm doing a little research into options for implementing an integrated temperature sensor into a design.
I've been looking into CMOS and BiCMOS solutions for this and can't really find any documentation of the advantages of doing this in BiCMOS, they generally look similar, but there must be some sort of advantage for using this more niche process?
Cheers for any insight anyone can provide!
38,755
Whether its CMOS or BiCMOS has little to do with temperature sensing.
What is the design that you are planning on doing this "integrated temperature sensor" into?
paddynbob
Joined Oct 30, 2017
25
it's a control system for cooling a vibrometer! Its a uni project and hypothetical. Designed in Cadence etc
It's not a compulsory part of the course - at the moment we're using an off-the-shelf component, but for extra credit I'm writing a little about options for including temperature sensing built-in
paddynbob
Joined Oct 30, 2017
25
What is the purpose of the temperature sensor?
Is it to monitor the temperature of the vibrometer?
basically, yep! So outside is a temperature of 200oC, the insulation (plus some crazy other thermodynamic stuff i don't understand) keeps it somewhat above that, and my control system keeps it at 40oC plus minus a degree or two
38,755
Okay, so if the chip has a built-in temperature sensor, the chip would need to be mounted at the 40°C point, is that correct?
