Better design of PSU
old_beggar
Joined Jan 29, 2021
39
Hello all, I wonder if anyone can offer advice - I have 2 options, as per attachments - which (if either) is better? I've left off capacitors for clarity. Would it be possible to do it with just the 1 voltage regulator? I need to be able to set the output voltage, and to limit the current.
Input voltage will be about +35v, and output about +25v.
38,946
Definitely the left one.
If you put the current limit at the output, then you won't get good regulation of the output voltage.
Not readily with a standard 3-terminal regulator if you need a high-side current limit resistor.
You could add a small BJT transistor (e.g. 2N3904) to do a current limit with one LM317 if you can put the current sense resistor in the ground return to the regulator.
Note that a standard 3-terminal regulator has a reference voltage of 1.25V so the current limit is 1.25V divided by the series output resistor (the 0.25Ω resistor).
Thus, for a 1A limit the resistor would need to be 1.25V / 1A = 1.25Ω.
Papabravo
Joined Feb 24, 2006
22,116
Ohm's law should remind you that a power supply CANNOT set both the voltage level and the current level simultaneously. What you can get is a controlled voltage level with a current limit, but remember the load itself will actually limit the current. In the case of a shorted load, the voltage will drop when the current limit is reached. Maybe the voltage will go all the way to zero and maybe not.
old_beggar
Joined Jan 29, 2021
39
As it happens (sorry I left it off my drawings) the V-regs are LM338K so I should be able to go up to 5A (heatsinking permitting) hence the 0R25 resistor. I'm aiming for a maximum current limit rather than a constant current. My supplier has assured me that the 338s are genuine ST, and I've bought from them before with no problems, so I'll take Crutschow's advice and go with 1st one. Many thanks to you all for your advice.
old_beggar
Joined Jan 29, 2021
39
Ah yes, but I added the pot in parallel to 0R25 so that the LM338 can effectively "read" the set voltage across it, as the ADJ pin only draws 50μA as per the datasheet. I'll try it and see what happens!
38,946
Ah yes, that's true.
But that pot can't reduce the current limit, only increase it.
The current limit occurs when the voltage from the sense terminal to the output is 1.25V.
Thus, if the pot is set at the 50% point for example, the current must be 10A through the 0.25Ω resistor to give 1.25V.
38,946
I want to be able to set the current limit from about 100mA to about 4A
Two questions:
  1. Can the current-sense shunt resistor be put in the ground return (i.e. is the voltage supply floating)?l
  2. Do you need the adjustable current limit to work into a short-circuit (output voltage below 1.25V)? (It would still limit at the internal 5A limit of the LM338).
old_beggar
Joined Jan 29, 2021
39
1. Yes, the current-sense resistor could be in the ground return (might even be better for the purpose of displaying where I've set the limit), and
2. I'd rather the current limit (as far as is practicable) did not reduce the output voltage.
38,946
From Ohm's Law, that's not possible.
You can either control current or voltage but not both at the same time.
You can limit the current to some arbitrary value, but the only way to limit the current is to reduce the voltage when the current limit is reached.
My second question was related to whether you need to control the short circuit current (where the output voltage is below 1.25V).
38,946
Below is the LTspice simulation of an LM338 circuit with an LM339/393 comparator to control the current limit from near zero to about 5A.
It uses the power-on LED D1, to provide a voltage reference for the current limit control.
If the LED you use has a different on-voltage then my simulated one (1.7V) you can tweak the maximum current range by changing the value of R7 ( a larger resistance increases the max current)..
The simulation shows the current limit with the U3 pot going from 0% (96mA) to 100%(5.1A) in 25% steps.
Its main limitation is that it cannot control the current below 1.25V output, so a short-circuit can go up to the maximum output of the LM338.
old_beggar
Joined Jan 29, 2021
39
I'm sorry I misunderstood your 2nd question - yes, I'm happy with that scenario.
I shall build the above and see how I like it.
Many thanks for your help.
