How should I better design an Amplifier with a Comparator
BIjoy_3000
Joined Sep 19, 2024
9
Hello Community,
I am facing a problem while building an amplifier for a Photodiode in Photovoltaic mode.
I have connected a few photodiodes in series; then I applied a high-pass filter. Now I want to amplify the voltage signal across R3 (in the figure). I went with a non-inverting amplifier design with a comparator.
Screenshot 2025-05-12 at 07.02.43.png The problem I am facing is that during the first few micro second, the output of the comparator is like this:
That is because if I compare the inputs of the comparator:
So I am asking for some help for the betterment of my design.
Ian0
Joined Aug 7, 2020
13,278
Hello Community,
View attachment 349014 The problem I am facing is that during the first few micro second, the output of the comparator is like this:
That is what happens as C2 charges up to the photodiode voltage.
Is what happens in the first few microseconds important?
schmitt trigger
Joined Jul 12, 2010
2,229
Photovoltaic? Why not use photoconductive?
Search for trans impedance amplifier for photodiodes.
The circuit not only will be simpler, but it will be orders of magnitude faster and with improved range.
EDIT: and you won’t require a DC gain of 5000X.
EDIT 2: the OPA380 is already a trans impedance amplifier. Use the datasheet circuits and recommendations. Don’t re-invent the wheel.
BIjoy_3000
Joined Sep 19, 2024
9
Many thanks for the reply. I have to use photovoltaics since I want to see the possibility of harvesting energy. Accepting this condition, how can I improve the circuit?
NB: Being faster is not my priority.
BIjoy_3000
Joined Sep 19, 2024
9
I want to decode a message sent by the transmitter. Probably not urgent to have them, but it would be better to have them.
Ian0
Joined Aug 7, 2020
13,278
By an LED, simple OOK light modulation for now. The message can be slow for this prototype
If the circuit is already running then there won't be a problem, because it will already have gone through the start-up charging of the capacitor.
If you are trying to use a photovoltaic panel to receive the signal, don't forget the size of the junction capacitance!
BIjoy_3000
Joined Sep 19, 2024
9
Thank you, i will keep in mind
28,272
The circuit analysis is made much less easy because of showing it as a wiring diagram instead of using correct symbols. And the boxes with numbers AR NOT the correct symbols!!
And certainly the comments in posts #2 and #3 are valid. And also the comment in post #4.
