Jerry-Hat-Trick
- Joined Aug 31, 2022
- 855
Thanks for explaining, I must have missed this. Presumably the resolution of measuring would be related to the number of possible taps? and these would probably be switched with relays which would suggest to me that a resistive divider directly into the processor pin just measuring half the wave and relays via opto isolators would be the simplest solution and peak to peak measurements should suffice? Knowing the spacing of taps would help. Most mains driven devices are reasonably tolerant of minor voltage changes. Without wishing to be unreasonable, but it seems to me to be another example of trying to solve a problem without saying what the problem is. On the plus side, it’s interesting to see the various approaches!The TS is designing a "voltage stabilizer". The AC line input might vary above or below the target output Line voltage.
It is supposed to monitor AC line voltage and adjust the line output (thru a selection of taps on an auto-transformer) to keep the output at a stable level. The TS has discussed this project in other forums. Its also supposed to detect over/under voltages
