Parallel power rectifiers is frowned on because of poor reliability - any one shorts and you're back to full power whether you like it or not.That's why I recommended at least 7 in parallel , that gives plenty of lee way ....
if nervous put all 20 in parallel ... with 20 the average current in each is 0.75A , even if there is some hogging it will never be so great as to cause failure .
or better find a single diode that can handle the required current ... diodes must be a cheaper and more sensible option than anything else.
I'd go for a single rectifier AT LEAST the fuse rating, preferably double. It will still need a heat sink, which will make safe mounting more hard work.
