Best way to power MCU's off batteries?
jdraughn
Joined Jan 30, 2009
33
I have always had trouble wondering how I should power my 5v PIC's when using batteries. Like for instance, the datasheet for my PIC18F4321 says 5.5v max, but 4 1.2v nicad batteries will have a voltage closer to 6v when full charged.
I don't know much about LDO regulators, but they still have a drop out voltage so when the batteries are at 4.8v to 5v, what does the regulator do, just bypass it self and output the voltage straight out?
So I have looked at using buck boost regulators so I can just use 2 or 3 cells and the regulator will boost the voltage to 5v. This kinda seems the way to go but it just seems to me to be unnecessarily complex and introduces switching noise and more expense.
I am also planning on trying to make the switch to 3.3v microcontrollers, there so many IC's I would like to use, but they all use 3.3v power and logic and 5v will burn them out, sounds like a 3.7v LiPO with an LDO regulator would be perfect for these.
Can anyone recommend any good solutions? I want to try building a few different projects that require long battery life and/or high effeciency so my projects will run for weeks or months at a time, or with a small solar panel.
R!f@@
Joined Apr 2, 2009
10,014
If you want high efficiency than you should consider everything.
Not just the LDO but the type of IC's too
tyblu
Joined Nov 29, 2010
199
A LDO regulator can only output it's rated voltage if the input is that rated voltage plus the dropout voltage. At source voltage decreases below that that, the output also drops. Note that many micros designed to run at 5V can run at lower voltages without any issue.
thatoneguy
Joined Feb 19, 2009
6,359
Which PICs are you using? Many of them will run fine at 3.3V, but the LF/low voltage PICs can only run at 3.3v and not at 5.
Check the datasheet first for minimum voltage.
I usually power simple things with either 4 AA Alkaline or 2 3V Coin cells, both with a 78L05, which is good to 5.5V. By the time the AA batteries hit 5.5V, they are fully dead.
I've seen some use just a diode on a 6V battery supply and not have big issues, but I wouldn't recommend since there is no regulation. A steady voltage keeps all the analog parts (ADC, Comparators, etc) running happy, and the internal oscillator speed stable.
For a bit more money, 2AA batteries run for a long time with a boost converter bumping the voltage to a regulated 5V.
nerdegutta
Joined Dec 15, 2009
2,689
My PICs run on 9v or 12v with a .1uF cap on the in pin of a 78L05 and a 100uF electrolytic cap on the out. Both caps goes to GND.
I use the good old 16F628. :)
t06afre
Joined May 11, 2009
5,934
The best thing is to not use any regulator. Circuits like 7805, LM317 and simple Zener regulators are not very battery friendly. If you post your design we may come up with some design desing ideas.
jdraughn
Joined Jan 30, 2009
33
Thanks for all the responses guys. I have made the switch to 3.3v pics so I can use the wireless MRF24J40MA 2.4Ghz tranceivers and have found that either a single lipo cell or 3 "AA" or "AAA" batteries are perfect with a 3.3v LDO.
