Hi all,
I am using HY301-07 which I need to power from 12V. What will be the best / simplest way to power the IR ?
To use a current limiting resistor in series, that would cause a low of power drop (i.e. will require high power resistor). Also tried experimenting with voltage divider, but this does not seem to work well, presumably as the IR is a current driven device, not a voltage powered device.
Also suggestions of how I can do this effectively and in the simplest way?
