best way to drop 48 Vac to 24 Vac
The spec sheet doesn't even give the VA specs and this is GE, the guys that build nuclear reactors. It's shamefull. I'm sure it's not a gazillion Watts.
The primary and secondary of a transformer don't really matter a whole lot. The VA rating will be the same, but @Bordodynov is correct, you have to size the 120 winding by current first.
So if you need 1 A at 48 V or about 50 VA, your going to need a 120 VA transformer. 1 A * 48V on the primary side,
The primary is usually on the core, so there is better magnetic coupling. You could loose some regulation.
So, dropping 48 V to 24 V, you need to know power. Many control transformers are 50 VA, so I just picked it.
These https://toroid.com/Products/General-Isolation-Transformers are probably too expensive.
You also might e able to use another x:24 V transformer and add or subtract voltages directly as long as the phase is the same. I thought the OP/TS listed the 3 phase voltage available.
MaxHeadRoom
Joined Jul 18, 2013
30,885
I guess I am just not understanding how this drops the voltage to 24v. So I am winding a coil i guess? What size of copper? How many turns? Series is where current flows through one then through the next.
I have 10 of these and just seems like a waste.
Maybe I misunderstood, from your previous posts I understood you had a number of these coils, or at least more than one?
If this was the case then use one to series up with the installed one.
Max.
diebog
Joined Mar 23, 2013
223
Max.
Oh now I get what your saying. Ya i have 10 of these or so, Thats simply easy. Why didn't I think of that? I have other contractors that I can use the iron core that these usually sit over. Thanks again Max
