But IMO if you are going to lay out cash on a remedy, it may as well be with the right component!I was afraid it would come to buying the right parts. I have 10 of these and just seems like a waste.
Like I said back in post #2
That will put half-wave DC on the coil, which it may not like.Just put one diode on it in series
You could always give it a try with the items already on hand, ensure the coil cavity has a iron core and wire it in series.Ok I am not following this. Are you pulling my leg?
Just put 2 pieces of box tubing inside each other?
You cannot put a diode in series with an AC solenoid and get the same results at 24v.
It requires full wave AC in order to work and produce the correct inductive reactance.
Max.
I will correct you a little. Apply 48 volts to the winding of 220 volts, and with the winding 110 volts you get 24 volts. But there is one "But". The resistance of the windings can be quite large and this can substantially limit the load current. Or use a very large transformer.A 240 to TO 120 V transformer. Apply 48 to the 120 V side and you'll get 24 out. Don't know if you;ll save any money and you'll confuse the next guy.
