best planar phased array implementation with passive feeding network question
yef smith
Joined Aug 2, 2020
1,481
hello i would like to implement a planar phased array.
the biggest problem in phased array is the radiation leakage from the feeding network.
Is there some phased array configuration for passive feeding network with is considered to be the best regarding purity of output radiation pattern?
Thanks.
Delta Prime
Joined Nov 15, 2019
1,311
Hello there :) Well, that depends on the complexity of the design, how much you are willing to spend on that design.
The antenna element coupling, along with the geometry of your array.
I'm quite gun shy when speaking in generalities as you know it leaves too much room for interpretation.
My lunch time is over so sorry I got to go but I'll be back.
yef smith
Joined Aug 2, 2020
1,481
Hello Deltaprime,i am willing to try and learn implement plannar passive phased array as best as possible.
It would be great if you could reccomend me some common implementation so i could try and work on it with a simulator.
Thanks.
