Best Microchip Programmer These Days
MrAl
Joined Jun 17, 2014
13,791
Hi there,
Have any idea what the best MC programmer is these days, that actually works without a hitch? I would like to upgrade my very old one.
Cost isnt necessarily a problem, but i dont want to pay for any subscriptions for ANYTHING, that's out now, and will always be out.
I want to target chips like the 12F1822 and 16F1823 and similar. They have lower voltage Vpp too my programmer cant do (as well as other things it cant do).
Oh also some microcontrollers with built in 2bit ADC chips by MC if possible.
I see out there a programmer "3" and another "4" is that a big difference between them?
I probably want to go directly to Microchip for the hardware but will consider other sources if you believe that are good. I dont have time for silly problems though.
Thanks much for any info.
JohnInTX
Joined Jun 26, 2012
4,787
Cost aside, I was going to suggest the PM3. I like that you can put the code image on an SD card along with all config info etc. so it's pretty goof proof for line workers and to have a ready archive of current versions for all projects. I have the adapters for ISCP, generic DIP as well as the adapter for old Promate II modules for really old stuff. What more could you want?
Unfortunately:
So.. good luck! I guess 'Universal' is not so much.
*so glad I'm retired*
MaxHeadRoom
Joined Jul 18, 2013
30,808
The only thing that deterred me from the Pickit4 was the mention in the ad is that it may not work with some older I.C's. Also isn't it non-compatible with the older MPLAB IDE ?
trebla
Joined Jun 29, 2019
599
PICkit4 is partially supported starting from MPLAB X 4.15. As far as i know the PICkit 4 supports most of the flash devices, except some special ones (rfPIC for example). See in the MPLAB X installation directory under docs file DeviceSupport.htm (something like that)
With MPLAB i use mostly PICkit3 or ICD3.
MrAl
Joined Jun 17, 2014
13,791
You mean apart from the Pickit 2,3,4 range?
Well not really i actually wanted to know about those three, and also anything else that might be out there.
Yeah i thought i heard 3 was buggy but wasnt sure if that was a knock off or a genuine Microchip product being used.
MrAl
Joined Jun 17, 2014
13,791
If you use MPLAB IDE 8.92, you may want to go with the Pickit 2 I found the 3 a little buggy, but it is OK on MPLABX .
What is the difference between IDE 8.92 and MPLAB X?
Do you mean MPLAB X doesn't work with older programmers?
I could go with PK4 i guess, but does it work well with MPLAB X?
MrAl
Joined Jun 17, 2014
13,791
Unfortunately:
Good to hear about but i probably dont need anything too advanced. A regular programmer should be fine.
MaxHeadRoom
Joined Jul 18, 2013
30,808
I prefer to use MPLAB V8.92, and Pickit 2 works best with this, but when forced to use MPLABX. I use the Pickit 3.
I primary program in assembly, so that limits it to MPLABX V 5.35. :(
I recently had to use a pic that had reconfigurable pins, 1618313, so had to go to the X ver. Otherwise, the older IDE programs quite a selection of the older Pic's
BobTPH
Joined Jun 5, 2013
11,645
That's good to hear. What kind of chips are you working with? Any that it wont do?
I work with newer chips, enhanced midrange and 24EP. It works with everything I have used recently, have not tried it with obsolete chips.
MrAl
Joined Jun 17, 2014
13,791
I use assembler too. Does this mean that the limit is v5.35, and is that version still available?
MaxHeadRoom
Joined Jul 18, 2013
30,808
You can download many of the older MBLABX versions, V5.35 is the last one that supported assembly programming.
Fortunately, most of the Pic's I use are supported in MPLAB 8.92 which I use with Pickit-2 successfully.
