Best method for reverse polarity protection and without power loss?
Fuji
Joined Nov 8, 2014
100
My power source is 9v for the entire circuit. As I undertand, the common way to prevent damages to a circuit would be to use a diode. Another method is a bridge rectifier However, I get voltage drops and lose power with a diode, and twice the loss of power with a bridge rectifier.
Taking to consideration for voltage drops with circuit protection, my question is if there is a possible way to make a reverse polarity protection without any loss of power at all? Or will there always be losses of power no matter what for this type of feature in any circuit?
30,772
What device are you offering protection for?
You could always increase the supply to compensate.
A single diode the polarity has to be correct, with a bridge it does not matter.
Fuji
Joined Nov 8, 2014
100
Thanks for the reply. It is not a product that I bought. I am building a circuit myself that is powered with 9v. It hit my mind that I wanted to protect the circuits. Right after the power source of 9v, I have a buck booster. I thought maybe protection before the booster would be beneficial.
So what your saying is, maybe increase the voltage by say...1.5volts, which then = to 10.5v just to compensate 9v? Sounds like a good idea.
For 9v power, is a 1A diode or Schottky diode (I assume is better for lower voltage drop) good enough?
blocco a spirale
Joined Jun 18, 2008
1,546
Diodes are often fitted in parallel with the supply and after the input fuse to protect against reverse supply polarity. There will be no voltage drop but supply reversal will pop the fuse every time.
MikeML
5,444
Every mobile HF and VHF transceiver (Ham and Commercial) I have seen has a 30A reverse polarity rectifier across the 12Vdc power input the radio with a 8 to 25A in-line fuse in the +12V line. Some also put a fuse in the -12V line too, but that doesn't involve the reverse rectifier.
If the installer does the dumb thing of connecting the power backwards, he would instantly smoke the radio if it were not for the reversed rectifier, which typically has a peak surge rating of ≥~500A, so that it can vaporize the fuse...
30,772
The bridge is very common on 24vdc Hydraulic solenoids where there is a BEMF diode and a LED indicator used, allows connection without regard to polarity mistakes.
ErnieM
Joined Apr 24, 2011
8,415
As Figi is asking for a zero power loss protection circuit then any and all schemes employing a diode are missing the point. A MOSFET will only loose power due to the drain to source resistance, which can be very very small for modern devices.
A MOSFET is a most useful way of dealing with things AS LONG AS THE INPUT VOLTAGE IS LIMITED. If the input can exceed the gate to source voltage then either the method is not valid, or some voltage limiting is necessary. A resistor and zener can work well there in many cases, though it may loose some power to run the zener for circuits constantly running over the Vgs limit.
38,668
This is what I would do, cheap, easy and as stated no voltage drop.
I'm not sure that the cost of a diode, fuse and fuse holder is less then the cost of a MOSFET and a resistor. And if the voltage is accidentally reverse connected with the diode, then you will need to find a replacement fuse (and of course we all have those on hand). :rolleyes:
LDC3
Joined Apr 27, 2013
924
... all schemes employing a diode are missing the point.
You misunderstand how the circuit is put together. The diode is parallel to the load and (usually) reversed bias. When the power is connected correctly, there is no current through the diode. If the power is connected incorrectly, current flows through the diode and blows the fuse.
ErnieM
Joined Apr 24, 2011
8,415
On the contrary it is you who miss the implications of your proposal.
Connect power in reverse, fuse blows, the rest of the circuit is intact.
Now connect power in proper fashion. Circuit does not operate as there is a bad fuse that needs to be replaced.
Thus this circuit accepts failure as an option.
