Known as burst errors, which is why many error-correcting protocols try to spread out the bits protected by each parity bit.I've done some work using various radio signals.
In earth environment, Error rate is highly dependent upon signal level, but when errors do occure , they tend to be across multiple consecutive bits.
But I'm interested in what @JohnSan's experience was with his system, because it seems somewhat similar to the TS's system, although signal levels may not be comparable. It still gives a first blush at the kind of error rates that the TS should consider.
