Best brushed DC motor driver?
minte_7
Joined May 19, 2023
11
I am looking for the best driver to control a 3V Brushed DC motor, maximum current in stall is about 100mA.
- The motor should have current control on the motor, being able to cut the power supply when it exceeds a previously configured limit.
- It must be able to control the motor in both directions. Selected using two switches.
- System powered by 3.7V battery. Battery charging could be managed by an external module.
I would appreciate any suggestion.
Thanks in advance.
LowQCab
Joined Nov 6, 2012
5,102
Why must the Circuit incorporate a Current-Limiter ?
According to your Specs, the Motor will only dissipate 300mW in a continuous "Locked-Rotor" condition.
That must be a really teeny-tiny Motor.
