Best and fastest way to drain a battery
Yeneef
Joined Sep 20, 2023
4
As SgtWookie noted, an incandescent bulb is a good way to discharge a battery since their resistance reduces as the voltage drops, tending to maintain the discharge current. Just use more lamps or a larger lamp to obtain a faster discharge. But don"t exceed the batteries maximum current rating (not necessarily determined by the AH rating).
