sometimes . . . the voltage regulators do not like diodes . . . at certain places (the suspects D9 CLED2)
if i remember right - then the optimal value for R4 R11 is 120Ω ← me.self-chk. 1.25V / 120Ω = 10mA ??? the regulator's ADJ pin uses 400µA to 5mA
i don't remember the reason behind the 120Ω anymore . . .
. . . is likely there
** Adjustment Pin Current Change -- ΔI.adj : Typ. / Max. -- 0.2 / 5 µA
Conditions : 10 mA ≤ I.OUT ≤ I.MAX , 3V ≤ (VIN − VOUT) ≤ 40V ← allows "good" regulation with no useful load attached (so it's not a must if you have over 10mA @ OUTP at any time) . . .
combined with (somewhat a "fuzzy math.") ::
Adjustment Pin Current -- I.adj : Typ./Max 50/100 µA and ΔI.adj : Typ. / Max. -- 0.2 / 5 µA →
→ R.adj = 1.25 / .1mA ≈ 12kΩ ← somewhat can be considered to be in parallel with your R4 or R11 (the smaller the R1 on the datasheet** the more precise the regulation)
→ ΔR.adj = 1.25 / 5µA ≈ 250kΩ . . . ×0.1% = 250000Ω / 1000 = 250Ω ← a maximum valuer for R1 to get 0.1% precision for OUTP voltage
