"beginner friendly" bldc motror controller?
Joe Stavitsky
Joined Apr 5, 2020
141
Can anyone recommend a board that's beginner friendly, but also allows for a fair amount of "adjustment"? I looked at ti c2000 and variants, but the devkit seems kind of involved with all the addon boards.
Thanks so much
Joe
Joe Stavitsky
Joined Apr 5, 2020
141
What are the details of the motor? What is its purpose? Voltage etc?
UAV. Not settled on target voltage yet.
Initially we will do this, just for practice, using standard arduino boards.
https://www.mathworks.com/campaigns...hms/motor-speed-control.html?s_tid=dl_prv_nxt
They have an arduino library, so we can program the board directly from Matlab.
Afterwards we will choose a smaller board amd a smaller motor. So, anything that minimizes time converting from matlab to the target code is optimal.
Thanks again
Joe
MaxHeadRoom
Joined Jul 18, 2013
30,768
Not sure of the end intention, but I have always tended to use secondhand drives, Ebay etc for motor control, one favorite is AMC.
Ebay $55.00
jamesper
Joined Sep 16, 2024
Thanks so much
Joe
I used a PICDEM MC-LV board when designing the original motor controllers for our AUV. We then shrank the design onto some small PCBs for the vehicle. That development board is long obsolete but I would expect that Microchip still have something similar in their range.
MaxHeadRoom
Joined Jul 18, 2013
30,768
We used those controllers on our original AUV around 30 years ago. We then designed our own which were much smaller and more efficient based on a PIC development board design.
I liked them because they were 0-20ma control , transconductance drives, and fit well with the Galil motion controllers I was using for CNC.
jamesper
Joined Sep 16, 2024
Regected424
Joined Nov 27, 2022
8
Check out the circuit on the MotorCell over at microcell.io. It uses a single IC to drive a BLDC axial motor. This is a low voltage. low power system, but gets a motor spinning from an arduino with minimal effort. The IC uses a PWM input to control the speed. The circuit is open source. They even have an arduino library for the MotorCell module. This is based on the BD67173NUX IC.
