Via USB connectorAre You Providing Power via the 5-Volt Input-Pads, or via the USB-Connector ?
Thank youThen your only choice is to un-Plug the USB-Connector,
unless You are adept at microscopic-surgery on the Circuit-Board,
and the Patient may not survive the Operation.
Or, You can carefully splice into the USB Cable,
then identify the 5-Volt Power-Wires,
and install an inline-Switch there.
If you want the switch to be on the board, you should be able to identify the 5V lead out of back of the USB connector on the board, cut that connection, and wire a switch in series with the two cut ends.Via USB connector
