Battery Charger Design
Alex.T
Joined May 16, 2012
12
I'm tinkering with a battery charger project and trying to define the following:
The application has a requirement of having a wide input voltage range, ~90-300VAC to then be stepped down to 12 or 24VDC. I know of many manufacturers who have this sort of set up and I know for a fact that they don't use a transformer. How else could it be done? Can somebody point me in the right direction?
Thanks,
Alex
38,946
A switching converter that operates from the a wide variation of mains voltage is used which efficiently converts the mains voltage to the desired dc voltage. They do use a transformer for isolation but it is in the high frequency switching loop so the transformer can be much smaller than a transformer operating at the main's frequency.
Alex.T
Joined May 16, 2012
12
Thanks for all the replies. This is something I'm trying to do for work, it's more of an industrial application so I can't really depend on an ATX power supply. I will keep digging into and learning of these SMPS. If you have more resources, throw them at me :)
Thanks.
Alex.T
Joined May 16, 2012
12
Anybody mind posting a link to a data sheet for one of these that are AC to DC smps? Can't seem to find any...
