Batteries as OpAmp power supply
Lasonata
Joined Jun 18, 2019
7
Hi there,
I'm working with a differential amplifier and, in an attempt to reduce noise, I moved from a DC power supply machine to batteries of 9V (same voltage). However, just when I switch to battery supply, I can see in my oscilloscope how I lose the signal I generated.
If the voltage for power supply is the same, why does it stop working? Are all batteries suitable for this task?
Thank you very much!
