I created this circuit to amplify the frequencies the bass has problems of reproducing (frequencies under 100 Hz). This was part of an university project. This entire design is based upon three things. The filter (the sallen key filter shown left above), the sum operational amplifier and the equaliser. The equaliser is the capacitor in parallel with the resistor, just behind the filter. The final product is listed in the picture. I simulated this circuit in CircuitLab and I got a desired result. However while testing this circuit physically, it didn't work. I used as opamp the TL072. I would like to know if there are some improvements, you think should be made or if there are parts wrong. This circuit was made by scavanging some parts on the internet, with an exception to the equaliser, which I thought of my self.
Side information
Filter is a second order buttersworth filter with a cutoff frequency at 100 Hz.
The equaliser will at 100 Hz have a +90 degrees phase. This has been made to equalise the -90 degrees the filter will output at 100 Hz.
Side information
