Hello
I have designed and built a basic robot circuit for use as to demonstrate basic fire detection. The ronobt circuit uses a Genie 14 microcontroller with two LEDS which track light. This then decides which motor should be controlled from one of two different slave boards. The slave boards use 4 Mosfet transistors each to control the direction of rotation of each motor.
I used circuit wizard to design and compile the circuit and it all works great in circuit wizard. Problem is I have built the circuit in real life acouple of times now and the motors do not run and the transistors on the slave boards keep over heating.
I have included diagrams/pictures below and also the circuit wizard files for any body to have a look at.
Any help would be much appreciated?
Andy
https://drive.google.com/file/d/1xFUhAMbWH1CS_UjuSPneHyIM4humihjt/view?u...
Andy
